1 members (Scott35), 524 guests, and 23 robots.
#131705 01/31/04 09:15 PM
Ryan_J Offline OP
How do you change a bitmap into a Jpeg?
Ryan Jackson,
Salt Lake City
#131706 01/31/04 11:30 PM
The very spartan MS Photo Editor [packaged with office?] will allow saves to jpeg, but you'll loose some resolution from jpeg compression. Doesn't look like MS Paint allows jpeg saves.
#131707 02/01/04 03:26 AM
Ryan;
(elaborating on Bjarney's message)
Software Applications for Image editing will do this .BMP to .JPG type of conversion. The conversion is done when the active (open) image file is being saved. The typical "Save As" Dialog Box in Windows Apps', will have a drop-down box on the lower portion of the "Save As" Window. Drop it down to select a new file format type.
Seems to me also that MS Photo Editor - part of the MS Office 97 (& up) Professional version - can save a .BMP to either .JPG, .GIF, or .TIF.
Applications such as Adobe Photoshop ($$$$mucho bucks!$$$$) and Paint Shop Pro ($$less bucks!$$) are able to save images in many different formats - including metafile types (.WMF).
Used Photoshop a lot for image edits, and liked the results. Lost the Application from a H.D.D. failure, and the CD-ROM original "Ran Away" from home [Linked Image]
Currently using Paint Shop Pro, ver. 7. Great results and many capabilities on this Application.
Other Apps' which may perform .BMP to .JPG saves would be ones which come with Scanners (Scanning Packages) and Digital Camera imagery.
Seems like Netscape Composer had these functions too...???
Scott35
#131708 02/01/04 12:01 PM
Ryan_J Offline OP
Thanks guys. I didn't think it would be too difficult, but it was something that I had never done before. Thanks again [Linked Image]
Ryan Jackson,
Salt Lake City
#131709 02/02/04 08:05 PM
K
The small program Irfanview is great for viewing all types of images and can save in just about any type you can think of. You can also do some image adjustment and open several other types of files with it.
I couldn't get along without it.
www.irfanview.com
#131710 02/16/04 08:22 PM
Ryan_J Offline OP
How do you turn a real media file into an Mpeg?
Ryan Jackson,
Salt Lake City
#131711 08/11/04 03:10 PM
Hello all!
I have a scanner (not yet discovered) and it has saved the file in some xtr or what extension. So next I'll need a free programme to open and change to jpg, cause paint doesn't recognize this ext. Can anyone help?
Thank you!
I have it now. :~)
Export, that is what to do.
[This message has been edited by Gloria (edited 08-12-2004).]
The world is full of beauty if the heart is full of love
