1 members (Scott35), 509 guests, and 39 robots.
#128248 12/12/02 08:59 AM
The guys in the crew have stumped me again.
We've been getting fluorescent fixtures with dual-rated electronic ballasts as of late. (As far as I know, the ballasts are not yet available for replacement use, I've only seen them on new fixtures). 120/277 photocells have been around for awhile.
When installed on a 120V system, they can be used later with a 277V system, but once 277V is applied, they cannot be used again @ 120V.
How does this work?? Is there an electronic device that "burns out" at a specified voltage?
(I've been wanting to smash one and look inside, but the opportunity hasn't yet presented itself). Thanks...S
Scott,
I am not sure why this has happened (maybe in the realm of an EPROM???), but it's worth checking into!
IF/when I find an answer I'll post it here.
Scott s.e.t.
Could be some sort of "avalanche" device, such as a zener diode combination which will only conduct on the higher voltage. This could be used to blow a small-value fuse which adjusts the settings on the supply.
Purely a guess...
