1 members (Scott35), 419 guests, and 22 robots.
#127929 03/19/02 11:51 AM
aldav53 Offline OP
When measuring 3phase feeders with an amp clamp on a 100a panel, I believe each phase is good to 100 amps, but we do not add all 3 phases to have a total of 300 amps, correct?
#127930 03/19/02 03:38 PM
Bob Offline
You are correct. The panel is rated 100 amp
3 phase. Each phase is limited by the breaker and the conductor rating. As an example you might measure A = 50a B = 60a
and C = 50a. You do not add the total and
get 110 amps.
#127931 03/19/02 08:30 PM
Ron Offline
If you were to measure 80 amps per phase, it would be 80 ampere, 3 phase on a 100 ampere panel. And, the utility will charge you for the equivelent of 80 amperes, 3 phase which is more than 80 amperes 1 phase.
Ron
