0 members (), 182 guests, and 25 robots.
#124222 09/06/06 12:56 AM
I dont see any factory smoke. I must be gone already.
#124223 09/06/06 01:35 PM
Bad capacitor,
Easily fixed.
Most people would just junk the whole thing.
If I'd had a dollar for every time I've changed a capacitor in any A/C unit, I'd have a good pile of money.
That and fan motors in the evaporator unit.
Cool pic, Adam!. [Linked Image]
You must have hit the button at the right moment.
#124224 09/06/06 01:53 PM
"...still works not bad when it's not spewing smoke and fire"
Probably could be said for an awful lot of people... [Linked Image]
[This message has been edited by mamills (edited 09-06-2006).]
#124225 09/06/06 05:57 PM
Hey all, glad you liked the pictures.. If I ever have the oppertunity do get more like that I will do so and post them on here...
Napervillesoundtech / Trumpy: I absolutely HATE chucking something if I know I have a chance at fixing it, if its not worth repairing I will raid any good parts out of it first, thats why I just happened to have two capacitors kicking around to replace that one. A little " rewiring" and modification to make them fit, and it works good as new.
To be honest I had to find the value I needed for the compressor by "trial and error"...
Couldn't find any numbers anywhere. 35Mfd started the compressor but the current draw on the compressor was way high, a 24 Mfd brought it back to about 6A where I think its supposed to be, starts and runs fine, and the voltage rating of the cap (400V) is sufficient for what I measured with it running (380V MAX)
Found the value for the fan motor capacitor with the multimeter, that section of the original capacitor was still intact. a 5 Mfd @400V worked out just fine [Linked Image]
#124226 09/07/06 12:01 AM
Ya know what this is-- it's an old-school heat pump! it magically senses when it's too cold, and shorts itself to add heat to the room. Or not...
