#122360 10/25/05 07:12 AM
From Lostazhell (Randy)
I got a call to a 1940's home where the breaker for the kitchen wouldn't reset.. The homeowner stated she'd called the utility and then she handed me a note from them (I had to LOL at the last line ) I noticed the 8/3 romex strung up between the house & the garage.. And then narrowed things down to the outlet behind the stove, conveniently also behind the gas shutoff
I got a call for a country clubs "maintenance barn" in which the maintenance person stated that "the lights would take forever to come on"... A loose neutral in a subpanel was the culprit causing unstable voltage (107/126V) Then this disconnect caught my eye.... It's feeding 2 subs plus the dinky thing on the left there
[This message has been edited by electure (edited 10-25-2005).]
#122361 10/25/05 07:38 AM
I got a call to a home where a home inspector had pointed out that a "2 wire outlet in the garage should be replaced with a more modern 3 wire outlet with GFCI protection". He didn't mention anything about these..
A financial center that I went to with a leaky roof causing a GFI to trip. I was surprised to find the romex in there...among the other issues
#122362 10/25/05 07:50 AM
From the note.
Must have qualified person correct. If you are qualified that's OK
Depending on the rules in your area for better or worse this could be true.
I have learned that here where I live only a person that installs wiring for a fee has to be licensed, permitted and inspected. [Linked Image]
It may not be what they wanted but it is how the law is written. [Linked Image]
Bob
#122363 10/25/05 07:53 PM
In the pics for the country club barn, do I see the "dinky thing on the left"'s feed on the line side of that disconnect?!?
Stupid should be painful.
#122364 10/25/05 08:47 PM
MX, you got it.... and btw, that disconnect is the service disconnect.. the line side is straight from PG&E. [Linked Image]
Bob, The reason I found the utility note humorous is just the fact of leaving it up to a homeowner to decide if they are "qualified". I could seriously see that last line being misconstrued. In CA, a homeowner is permitted to pull their own permits and carry out their own work, electrical or otherwise..
-Randy
#122365 10/25/05 11:20 PM
mxslick
Lostazhell
What does that dinky thing feed?
#122366 10/26/05 02:26 AM
The front of that door on the "dinky thing" said "fuel pump", but I didn't see anything resembling any type of refueling facility... possibly it was installed used?
#122367 10/27/05 06:55 PM
My thought might be that it might be supplying power to a well pump or fire pump..
#122368 10/28/05 04:26 AM
Interesting Randy,
From the note:
Breaker I left OFF is BAD.
Replace to correct.
Not a PG&E problem,.
Must have Qualified person correct.
If you are qualified that's OK.
In that top pic, that's a way of using an LB that I've never seen before.
Is that water or gas in the 4th pic Randy?.
Boy, has that recept in pic no. 8 been mis-treated or what?.
Looks like a guy with two black eyes and an open mouth on the top. [Linked Image]
#122369 10/28/05 07:55 AM
..Looks like a guy...with two black eyes...and an open mouth...
It's my Mother in Law!!
