516
17
Posts: 3,682 Likes: 3
Administrator Member
The gutter shown in this pic contains the main feed to a number of panels at a shopping center. Some extra holes were filled with.....some interesting 'plugs.' Anyone know what they were really intended to be used for?
- renosteinke [This message has been edited by Webmaster (edited 10-02-2005).]
They look like the plugs plumbers use to seal lines for pressure/standing water testing..... Someone got creative....
Stupid should be painful.
What an electrician that did not have any 4" square blanks?
Anyway I will go with slicks thought or maybe plugs to be used when heating PVC for bending?
By the way I would also say they where punched out for either pulling or feeding the wires in the opposite pipes. The folded one also.
These are T&B Push-Penny® Plugs. I thought they were for plugging conduits. I never saw them used as KO blanks.
Plug, Conduit, Connectors (Push Penny® Plugs)
Economically seal out grout and plaster from any fitting or raceway conforming to CSA dimensional tolerances. Made of flexible plastic, they push into place and are held fast by pressure against internal surface of fitting or raceway. Eliminates need for separate capped bushing or steel penny and bushing.
Application
[*] To plug open end of conduit or connector in order to prevent ingress of trash, dirt or moisture during construction and remodeling.
Features
[*] Wide range of application; can be used with rigid metal conduit, intermediate metal conduit, electrical metallic tubing, all connnectors and all bushings.
[*] Designed to stand up to normal handling and is functionally unaffected by moisture.
Standard Material Polyethylene
Standard Finish As molded
Listed/Certified by: CSA (LR2884, LR4484)
Conforms to: U.L. 514B CSA C22.2 No. 18 NFPA 70-1999 (ANSI) NEMA FB1
Push-Penny® Plugs
Cat# Size 1470 1/2" 1471 3/4" 1472 1" 1473 1-1/4" 1474 1-1/2" 1475 2" 1476* 2-1/2" 1477* 3" 1478* 3-1/2" 1479* 4" * Not CSA Certified CSA File No. 2884 UL not applicable
[This message has been edited by tkb (edited 10-02-2005).]
I wonder how many younger electricians would know what a "penny" is when used in electrical context?
Larry LeVoir Inspector City of Irvine, CA
it's easy, a penny is a high current fuse link that is usually protected by the wiring in case of a fault
JFW
"The penny" has been replaced by "The ductape" in the minds of younger guys I think, Larry.
