Electricians revenge
1 members (Scott35), 128 guests, and 12 robots.
#120389 04/07/05 06:45 PM
Here are some pics of a job where the guy was certainly aware of all the different wiring methods; he just didn't believe in supporting them.
Renosteinke
EMT needs to be supported every ten feet, and within three feet of every box. (358.30)
Sealtite needs to be supported every 4-1/2 ft., and within 12" of every box. (350.30)
Flex needs support every 4-1/2 ft. and within 12" of every box. (348.30)
Boxes need support. (314.23)
#120390 04/07/05 09:34 PM
While it doesn't excuse the original crappy work, I can nearly guarantee that most of the mess here was caused by a re-roof job. Nobody called an electrician to get conduits out of the way and then reinstall them. I see it all the time.
#120391 04/07/05 10:42 PM
Nice touch including the code sections.
#120392 04/08/05 06:47 PM
Greg, that's not a bad guess...but the truth of the matter is that this resturaunt- once notorious in this town for mixing dog food in its' dishes....grew from a small house to a thriving business, with many additions along the way. The wiring you see was all done, as you see it, by the HVAC/ refrigeration guy. What sleepers you see are glued in place, left from a prior install, and not used when the lines were run again.
#120393 04/10/05 07:06 AM
K
If this was the work of an unlicensed HVAC /refrigeration technician, then are you legally required to report it ?
#120394 04/10/05 12:44 PM
e57 Offline
I was figuring a roofer too. As I have had that done to me. Tore up everything so they could roll sheets.
#120395 04/11/05 07:33 AM
Actually the conduit is supported...its laying on the roof, but it is not secured as required by the code.
Don
