1 members (Scott35), 524 guests, and 23 robots.
#120264 04/04/05 06:49 PM
I was a little disappointed to see that NEC 358.24 only says that bends "be made so that the tubing is not damaged." I suppose, though, that the further specification that the radius "shall not be less..." could apply to finding a violation to the sort of free-hand bending as is shown in this photo.
Why spend $8 for a bender, when you can tweak the pipe between studs, bricks, or a handy bumper? :-(
- renosteinke
#120265 04/04/05 08:22 PM
Reno,
I do think the tubing is damaged.
Aah, maybe I'm just picky [Linked Image]
#120266 04/05/05 09:21 AM
Does it make the electrical installation unsafe if the tubing remains undamaged?
Ryan Jackson,
Salt Lake City
#120267 04/05/05 03:36 PM
No Ryan, but if I installed the pipe in the pic, I would certainly hope nobody ever found out who did it.
#120268 04/06/05 06:59 PM
I think this might fail the "workman-like" test. I confess that I've improved the angle of a conduit over my knee several degrees occasionally when deep in an attic or crawl-space.
Dave
#120269 04/06/05 08:54 PM
I suspect that one of the bends made is too small in radius to comply with code...and the EMT almost certainly has a "flat spot-" even if this guy stopped just short of a kink.
With workmanship like this, no one should be surprised to see that the EMT is completely unsupported, or to find #12 wires serving a 30 amp water heater (yes, he did that also.) And, of course, no ground wire- even though there is flex used.
#120270 04/06/05 10:59 PM
That sounds OK... if he used 2 per leg [Linked Image]
Of course, about the grounding wire... if the flex is under 6', is is required?
[This message has been edited by DougW (edited 04-06-2005).]
#120271 04/08/05 08:37 PM
Good catch, Doug....that is one of our local requirements: all flex, sealtite get a ground wire.
#120272 04/09/05 10:16 PM
WM, 110.12 issue there too. Looks like a 90 with 2 kicks, a twist, and a curl. Unbelievable.
#120273 04/12/05 10:17 PM
Joe handy man at work.
ed
