552
33
Posts: 3,682 Likes: 3
Administrator Member
Joe, these pictures may not be as bad as they look. Generally the NESC requires 7.5' to 10' of horizontal clearance. In this case, the electric utility used Hendricks Cable System for the primary conductors. The Hendricks cable is fully insulated for trees and areas like this where clearances can't be met any other way. I suspect the transformer bank has more clearance than the pictures indicate. - - - - - - - - - - - - - - - - - - - - - - - - - - - Charlie Eldridge, Indianapolis, Utility Power Guy
Charlie Eldridge, Indianapolis Utility Power Guy
Based on transformer sidemount primary-bushing and arrestor sizes, a guess is it’s “tree” or “covered”-wire (versus insulated) spans at 4kV.
Zero effort has been made to cover taps, splices and terminations. This seems at best ‘on the edge’ for utility distribution. [hendrix-wc.com]
I have wondered the same thing last time I was heading to Lechmere, but as I recall, those lines aren't as close as the pictures make them seem.
Hi gents, I used play on those tracks as a kid, I think? I recognize the Cambridge Courthouse Building in pic #1 at the far right. Is this on 28 (O'brian)? Looks like the bridge to Everett/C-Town? (Been a long time.) If kids in that area are anything like some of the ones I grew up with, they didn't use isulated for trees, they did it to keep people from thowing pieces of pipe on them for fun!
Can't remember what the name of that road (Causeway) is? Are the Edison Stacks to the left behind you here in Pic #1?
[This message has been edited by e57 (edited 09-15-2004).]
If that's a new pole being installed in pics 3 & 4, when it's finished, you'll be able to do chin-ups on the crossbeam.
What is the OSHA clearance, 10' to conductors >10kV? Something like that.
I remember a 3rd floor balcony with primary within arms reach (not that I tried proving it or anything).
I've seen stuff like this lots of times and it never ceases to amaze me. I don't pretend to have any knowledge of the NESC but 3-4' from a balcony?
Oh, yeah, and I remember the POCO manual in that area said, "Do not mistake the covering that may be observed on our wires for insulation. Any contact with our wires can kill you."
The primary that was 3-4' from the balcony had a black covering on it that looked not too different from 600V insulation.
