1 members (Scott35), 528 guests, and 25 robots.
#118015 07/24/04 12:31 AM
I spotted this when I pulled off a road to call a friend for directions... This is along the 217 Fwy in Goleta, CA.... I wonder what burned first here... The panel or the brush that was around it!
-Randy
#118016 07/24/04 11:32 AM
What did this panel supply? Looks like the 2 pole on the right is being used as a back-fed main.
#118017 07/25/04 02:12 PM
Is that a field cut oval hole in the back of the panel that the conductors are running through?
steve
Steve
#118018 07/25/04 05:51 PM
Electricman2,
The only thing I saw in the area here was the sprinkler control cabinet to the left of this mess in the 1st pic....
Steve,
The oval hole looked like a factory job, But the edges didn't appear to be rounded out, nor was there any sign of a bushing being installed... I'm going to try searching some of the local papers online & see if I can get some info on the fire cause..... That opening & the completely bbq'd phase looks suspect, except for I'd think it qould've eaten out a chunk of the opening while faulting!
-Randy
#118019 07/25/04 11:09 PM
Was that a Myers pedestal? You could always recognise them by that nasty green color they used.
P.S. Are the still in business?Since Cooper has the Scru-tite hub line now I was wondering.
#118020 07/26/04 07:54 AM
Myers still is making pedestals by the gazillions. They've got a place right by our shop in Corona, CA
www.myerscustom.com
Ryco (a subsidiary company) is up in Pomona, CA. I've had them actually build me switchgear on the spot while I waited in the parking lot!! A good bunch...S
(PS, except for the sickening gray/green paint [Linked Image])
[This message has been edited by electure (edited 07-26-2004).]
#118021 07/30/04 03:18 AM
Scott,
RSE Sierra in Anahiem does custom switchgear also, & they use Square D parts [Linked Image] They've come through for me many times in a pinch! (Not to mention they won't paint it green [Linked Image] )
-Randy
