1 members (Scott35), 524 guests, and 23 robots.
#116285 03/26/04 08:41 AM
They say "Water and Electricity don't mix".
Some of us think this isn't true
They mix all too well
What's happened - Will happen - here?
Images courtesy of Joe Tedesco
#116286 03/26/04 12:04 PM
Hopefully the glass globe in Pic #2 will fall off because of the added weight before the water level reaches the lampholder....
Am I the only one who really hates these receptacles with plastic straps? They seem "chintzy" and likely to break. At least in this case it won't corrode when the device box starts filling with mud, spiderwebs, garbage and water...
#116287 03/26/04 08:49 PM
Sven, I had not noticed the plastic ears.... I can see the ground screw in the box fairly clearly, and it looks like it is vacant. With plastic ears, and no ground wire, what good is a 3 prong recep. especially outside? This appears to be far worse than merely missing a cover!
#116288 04/06/04 09:08 PM
Ya know i have actually opened that box up and thats where i found Nemo. [Linked Image]
