1 members (Scott35), 128 guests, and 13 robots.
#115989 01/23/04 08:54 AM
That second photo appears to be British plugs and extension strips, and is an all too familiar sight!
#115990 01/23/04 11:41 AM
Yeah, it's a familiar sight allright. Looks like my workbench and the spouse's computer desk....
OK, which one of you weisen-heimers broke into my flat to take that shot? [Linked Image]
Wonder what role the TV antenna cable and splitter are playing in this picture....was this picture taken behind a home hi-fi rack system?
And then I see something that looks like a telephone box....on the wall.
[This message has been edited by SvenNYC (edited 01-23-2004).]
#115991 01/24/04 07:17 AM
Yes, that's a standard BT telephone outlet on the wall with a line disappearing somewhere into the tangle of wires.
It looks like a multi-way adapter and phone cord connected at the left-hand end of the white extension strip as well. It's probably one of those surge-suppressor strips that incorporate a telephone feed through.
#115992 01/25/04 08:16 PM
And this is what the end result will usually be when the loads are excessive!
Burned Up
(submitted via Joe Tedesco)
#115993 01/25/04 10:34 PM
Hol-eee geez.... How'd you (or the person who made this shot) cause this to happen?
What was plugged into it and shouldn't the fuse or -- now more commonly -- circuit breaker normally built into these things have popped and cut the current flow?
I thought these things were supposed to be made out of a type of plastic that didn't burn......
[This message has been edited by SvenNYC (edited 01-25-2004).]
#115994 01/26/04 08:55 AM
Is (was) that foil looking stuff some kind of shielding?
I guess I'll have to smash up one of these things to see what's inside...destructive testing is a "forte" of mine [Linked Image]...S
#115995 01/26/04 10:30 PM
Holy Shiite! Anyway, I've had these things apart, and there's no conductive shielding or anything other than cheap plastic inside. Aside from some brass rails that form the outlet contacts.
#115996 01/30/04 07:05 PM
i've seen a similar picture, where the fire was causes by a bad quality varistor (overvoltage/surge protection) that leaked internal insulation and got hot.
