Bill: Guess I should choose my words a little more carefully......
Like TheComputerWizKid said...it may fall over from the weight of the tag! I meant that if I was to "slap on the red tag" I probably would knock it over.
For the "After" picture of this install, look at the photo of another disconnect installed without support in the Violations section. It is about 1 swing of a ladder being moved from this to that.
Within a year or two this disconnect will be the perfect beehive. I was on a roof this summer that is common to 10 dwelling units. The A/C units are on the roof and the disconnects are mounted the same way. I tried to open one and it was full of bees. The reason for trying to open it was the A/C unit was not working. I am allergic to bee stings, so I went home early that day
