0 members (), 420 guests, and 16 robots.
#113652 09/09/02 10:47 PM
Thought I'd share this for the nostalgia area. Can anyone date it? The zinc rod is almost disintegrated. Could I replace it with a galvanized bolt? What would make a good electrolyte?
-Dave (Rabbit)
#113653 09/10/02 01:20 AM
Neato!
-Virgil
5 Star Inspections
Member IAEI
#113654 09/10/02 10:04 AM
WOW, now I know what I was looking at when I found a flexible metal rod in a junk yard. It was 3 feet long but was fairly decayed or eaten away. It was zinc colored and flexible. I had never held pure zinc so I didnt know what it was. THanks for sharing
#113655 09/10/02 10:43 AM
Your cell is a handsome find, Dave. Thinking out loud—don't think a zinc-plated bolt would give much life, and the iron might contaminate the electrolyte, but maybe that's not the point. When you see a jar one thinks of a flooded lead/sulfuric-acid cell. That would not work here for the acid would dissolve the zinc electrode without any current flow.
The old No.6 1½-volt “dry cell” used a paste electrolyte—may have been partially zinc chloride. In those, underneath a cardboard wrapper was a cylindrical zinc cup about 2½ inches diameter and 6 inches high. There was a 6-32 knurled-brass nut attached to the zinc that was the negative electrical connection [cathode.] The positive/anode connection emerged from the cell top-center with a similar brass nut. The anode was a carbon rod about ¾-inch in diameter; maybe 5½ inches long.
Believe it or not, there is reference to No.6 cells in the 1999 NEC...725-41(a)(5). Have to see if I can find more information about just how your cell is filled/operated, Dave. For you young’uns, the modern equivalent to No.6 cells are Eveready EN-6. They are advertised at ~$11-to-19 each. http://data.energizer.com/datasheets/library/primary/alkaline/energizer/industrial/e n6.pdf
[This message has been edited by Bjarney (edited 09-10-2002).]
#113656 09/11/02 06:30 AM
One thing you could try, is find a anode rod for a hot water heater, some of them are made of zinc. That would give you a nearly endless supply of zinc for the vintage crystal radio that you are going to use your battery with [Linked Image]
Trainwire
#113657 09/11/02 03:59 PM
I have two more of these. They are missing the zinc completely and are in square jars. All in series should light a 6v bulb for a museum display. More to come.
#113658 09/12/02 02:40 PM
Thanks for sharing the photos.
Try these places for metal (I haven't used their services):
http://www.vertic.fi
http://www.espi-metals.com
Hope that helps some...
[This message has been edited by ThinkGood (edited 09-12-2002).]
