536
33
Posts: 3,682 Likes: 3
Administrator Member
In my job for the local utility, I get at least one of these per week. Iowa doesn't have state or county inspectors. Only larger municipals have paid inspectors, and they usually double as plumbing & structural inspectors. Aside from the obvious violations, this guy used USE cable from the disconnect to the meter socket, the meter socket is not on our approved list, there is no hub on top of the socket (inside was wet from rain), and the pole doesn't belong to him! Thanks, Kevin Duke
Yup, that's pretty bad.
The "cellular" is a dead giveaway that they used plumbing pipe. (lightweight cellular core pvc)
What happened in this situation? Did the utility just tear the whole mess out?
Peter
I sure hope this was a homeowner that did this with the help of Home Depot's experts and not an "electrician"
Posts: 4,116 Likes: 4
It seems odd that they seemed to use some sealant in pic #2 on the connector but thought nothing of the two holes next to it. Bill
So much for the mandate "neat and workmanlike." There used to be an old-salt inspector in the LA, CA area that would often ask, "What does that mean?" He would often mention the stupidity of such a requirement; that should be tossed out as entirely unenforceable. Rest in peace, Joe Roohan.
Posts: 2,236 Likes: 1
Ah, yes... 110.12
My favorite code.
And the "all purpose" code...
For the very same reason the "old salt" didn't like it!
It is rather subjective...
For somebody without a clue, it's not too bad!
You know, maybe I'm all wet here. Even though this installation is a long way from compliance with any codes, It seems to me that the "installer" would at least take some pride in the work that he does. I guess what I'm saying...code violations (and legal issues...?)not withstanding, this is a really ugly job that anyone should be ashamed of!! Finished ranting...thanks guys. Mike (mamills)
Forget about the code for a second, does anyone know how the line conductors are going to enter the meter can. It appears to be an overhead pole with an invisible stack. Maybe the installer was hoping for a solar meter.
He forgot a strap, and i put the bare in from the bottom and bend it back over the clamp so when it gets loose you don't lose it in the dirt. buy em a book and send em to school.
Lighting the way
