#112486 06/29/01 11:58 PM
This was found connected to a 2 HP 1 Phase 240V Planer circa 1950. It's the result of a carpenter and a mechanic getting together on an electrical project.
-Virgil
#112487 06/30/01 06:31 AM
electricians make bad carpenters, carpenters make bad electricians...
#112488 07/02/01 06:51 PM
What's wrong with these guys? I thought even carpenters knew that you're supposed to use a BRASS bolt when you're replacing a fuse with a bolt!! What's the extra conductor for? Is it a dedicated phone cable for 911 calls?
(All in jest, this is really awful)
#112489 07/02/01 07:15 PM
Tom Offline
If there was a short circuit on the load side, would that be considered a "bolted fault?"
#112490 07/02/01 09:46 PM
Sure sounds right, Tom.
And if the short was right where they installed this little jewel, would it be a "faulted bolt"?
#112491 08/28/01 05:40 PM
...Only after the Nut welded itself to the threads of the bolt.
