Electricians revenge
0 members (), 40 guests, and 8 robots.
#112453 07/23/01 02:28 AM
Originally posted by sparky66wv:
In fairness to my intelligence, I would like to point out that these fiberglass rods are white/grey [b]NOT bright orange or yellow. If they had been orange or yellow, it would have been obvious.
I have heard of corner grounded delta, and was wondering if one could inadvertently ground any leg without things blowing up...
2400/4160? I believe it's 7200/4160, but I could be in err.
[This message has been edited by sparky66wv (edited 07-21-2001).][/B]
Sparky,
Yes they are sky grey when new but then after the sun gets to them for a few years they turn white and get very splintery.(hate that glass)
Yea 2400/4160. That is one of our secondary voltages in mostly older areas of town that feed some water/sewer plants and some factories. It can be either WYE or Delta. If its wired WYE then the cust gets 4 wire 4160Y/2400. If delta he gets 3 wire 2400.
As far as grounding a phase 3Ø 3 wire svc, yes you can. You are allowed ONE ground. But a word of caution is that you had better be dang sure that it is not already grounded by some means and you try and ground ANOTHER phase [Linked Image]. When we phase two 3 wire 480 svc's together then the only way is to place a temp jumper between the two svc's before phasing can be attempted. The reason for the jumper is because the two services do not have ANYTHING in common that ties them together. There is no neutral or a common tie. Was pretty scary the first time I ever phased 480. Was kinda leary about placing a jumper between two phases of 480 [Linked Image]
[This message has been edited by glenn35 (edited 07-23-2001).]
#112454 07/23/01 02:08 PM
Anonymous
Unregistered
I hope you realize that if you make telling color a measure of intelligence, I'm the one who gets the failing score...
#112455 07/23/01 08:57 PM
In Dspark's defense, I'll also say that I've seen yellow/orange ones, and the JPEG compression makes the color a little ambiguous...
-Virgil
5 Star Inspections
Member IAEI
#112456 07/23/01 09:48 PM
Anonymous
Unregistered
Hey, thanks! I wasn't taking it personally or anything. If you want to come to my defense some place that really counts, how about that 180° out of phase topic?
#112457 04/17/02 09:27 PM
I have a pole near my house where one wire is off of the crossbeam, but it is still on the insulator (actally, the crossbeam isn't there anymore). I called my utility co a few times, they did nothing. it's just there, swaying in the wind. it'll probably be like that for a few more years before it's fixed.
#112458 04/19/02 08:26 PM
around here they 'condem' old poles, put a red tag on em' and generally wait for them to fall over........
