562
43
Posts: 3,682 Likes: 3
Administrator Member
I was lucky enough to see this work as it developed. A new, upscale home was to have a receptacle placed in the living room floor. The contractor used an ordinary flanged plastic box, a clock receptacle, and then (amazing!) covered it with a proper floor cover. Since the box is not adjustable, there is a gap caused by the thickness of the hardwood flooring. The irony of this clever ruse -which slipped past the inspector- is that the brass cover plate cost quite a bit more than a proper plastic box / cover assembly!
- renosteinke
Eh?? mon dieu !! that will not pass the inspection at all that sure look very crappy there i dont know if the GC did know about this or not if they know this how they correct this mistake here ??
Thanks.
Merci , Marc
Someone needs a flipping good kick up the pants for the 'patina' being ground into that new hardwood floor too!
Yeah, never mind zero tolorance on the box at wood, the site preotection leaves to be desired.
