1 members (Scott35), 565 guests, and 35 robots.
#10823 06/19/02 03:13 PM
EVAD7 Offline OP
FOR RESIDENTIAL AC COMPRESSOR HOOK-UP--2002 CODE WILL NOW REQUIRE A 120V OUTDOOR RECEPT. IS THERE A DISCONNECT OR A METHOD TO REDUCE INCREASED COST AND WORK FOR INSTALLATION?
#10824 06/19/02 08:17 PM
Ron Offline
Place the compressor close to the recept provided in the front or back of the house.
Ron
#10825 06/19/02 09:56 PM
I'm sure some company will start making one, but I don't really see the need. The disconeect will surely cost a good bit more than a cheap A/C disconeect and the contractor will pay for the one you have to install and it won't be that expensive anyway.
#10826 06/19/02 10:34 PM
Not to mention that you pull a 10/2, 8/2, or 6/2 to a 240v compressor which means you have no neutral to serve a 120v recept.
