1 members (Scott35), 539 guests, and 25 robots.
#107457 09/22/04 08:15 AM
Thought you might get a kick out of this one. I'm doubtful that the Canadian code allows for wire to be buried in concrete, sans conduit, especially in a very very damp location (Vancouver, Canada).
- Derek L.
#107458 09/22/04 09:05 AM
Good Lord!.
It makes you wonder what the rest of the cable looks like, inside the concrete.
The chemicals in concrete aren't usually that kind to PVC. [Linked Image]
#107459 09/22/04 10:49 AM
Mike,
I've never heard that before. The most common underground installation in my area is concrete encased PVC conduit.
Don
#107460 09/22/04 11:41 AM
Don,
The type of PVC that is used for rigid conduit, is an un-plasticised version of Poly-Vinyl-Chloride.
The type used for wires and cables has a plasticiser added to it, to make it more flexible.
It is this plasticiser, that the acidic content of the concrete reacts with.
There are also forms of plasticiser that react with sunlight too and some overhead lines here have been known to lose thier insulation.
#107461 09/22/04 01:27 PM
Thanks Mike.
Don
#107462 09/23/04 06:00 AM
Nice custom in-use cover also!
#107463 09/23/04 01:11 PM
All the conduit is for in concrete is a raceway,if after the cement sets the conduit rots away or disintegrates no matter you have the channel and you must pull a ground.
#107464 09/23/04 03:50 PM
A guy from germany once told me the Mexican way of resi wiring. Put a greased garden hose into the concrete walls while pouring them. After it's set pull out hose and reuse. Then pull THHN into the resulting cavity. No ground, just a jumper wire N-G at every receptacle.
