I'm just trying to figure out the logic of things here:
If the Switch is for the Hydromassage tub it must be GFCI protected but can go in the space over the Tub?
If the switch is not for the Tub it can go right next to it and it doesn't have to be GFCI protected.
If the Hydromassage Tub is replaced with a Hot Tub the switch must be moved 5 feet away.
