WebSparky
I would make the corrections --- just to be on the safe side so that I will be aware of any that may be associated with the text and questions.
If you are taking the test for the IAEI certifications then you'll probably use a computer to answer the questions.
If you are taking an electrician's test then don't they prohibit using a code with any marks in it?
