You can tell what printing you have by the number on the inside cover at the bottom of your NEC.
If the Number 1 is shown, you have the first printing, and if it is missing and you see a Number 2 you have the second printing....
http://www.nfpa.org/PDF/Errata70-02-1.pdf?src=necdigest http://www.nfpa.org/PDF/Errata70-02-2.pdf?src=necdigest http://www.nfpa.org/PDF/NECHT110.26(A)Errata.pdf?src=necdigest
http://www.nfpa.org/PDF/TIA70-02-1.pdf?src=necdigest [This message has been edited by Joe Tedesco (edited 03-06-2003).]
