The few septic pumps that I have worked have a weather tight enclosure that is to be mounted outside the septic pump tank,that contain the controls/disco for the pump and the interface hook up for the float switches(pump on,pump off& high level alarm).Also mounted on the top of this enclosure is a red flashing light that is triggered by the alarm float switch.
Chris
