If those HV lines are putting out enough EMF to electrify the plumbing in that house, wouldn't at the same time, the wiring in the house pick up this same EMF and play all kinds of havoc with induced voltage? Something here smells of open/corroded/loose poco neutral, & unbalanced current using the plumbing trying to get back to the poco transformer... I'll bet on the difference in potential between the fresh water and the drainline in the shower are why he's getting bit
