me: the fan on this dryer is hitting the shroud.
Doofy: (wearing his shiny new company issued Fluke T5 ) ..
.......ok, I will change this big switch, and that motor coil....
For some odd reason I would have thought to inspect the shroud and the blades on the fan and maybe the motor mounting to see what is out of physical position or bent. Then look for the power disconnect so I can shut it down before removing shroud and correcting the mechanical problem.....
I wouldn't have thought to mess with thermocouples or controllers to fix a fan blace hitting the shroud...
