You also have the option of moving the service to the corner of the home and running
outside the home to the original point of entrance. That will permit you to do it without putting a disconnecting means on the outside of the home and the extra ground rods. The service can be left overhead or buried, your choice (you may have a charge from the electric utility if you bury).
Charlie Eldridge, Indianapolis,
Utility Power Guy
