Ditto the mighty Roto Zip. Now hear this. Put on your safety goggles and dust mask first. Then try the tile bit on cement block walls for knocking out switch and receptacle openings. Don't go all the way in on the first pass. Remove the guard to finish going all the way thru the 1-1/2" deep to the inner hollow core. Works great.
