Bob,
Also are you saying I am required to lock off all 3 breakers even if I am working downstream of spilting off to two wire circuits?
I think that you must lock out all of the hots to the multiwire branch circuit before working on that circuit. There is always the possibility that the grounded conductor would become open between you and the panel leaving you with a "hot white wire".
Don
