Thanks for the quick reply...I figured as much. As for the GFCI's, I've found that with many manufacturers, that's the only termination they provide.(back-wire) I really like those-a positive, tight connection.Incidentally, does anyone out there know if the NEC code re AFCI's will (or is) be applicable in Canada?
BTW, I am in Toronto.
[This message has been edited by mickky (edited 07-28-2001).]
