That begs the question, how do you make up a rain tight "T" in EMT?
I had the same problem when the state required all EMT to be using compression connectors, wrench tight. Legally you could not use a conduit body.
On the other hand a Bell box has straight cut threads so I am not sure what the difference would be.
