Swiss - Switzerland.
In Dublin I saw a girl who plugged her laptop (NEMA 5-15 plug) into a non-grounding NEMA-Schuko adaptor which was in turn plugged into a non-grounding BS1363 adaptor like the type mentioned by DJK. In Galway I saw someone using the very same "adaptor tower" with a hairdryer, both plugs pulled halfway out, of course no fuse.
I had a BS 1363 plug with 13A fuse, 50cm of H05VV-F 3G1mm2 and a Schuko trailing socket. Only slight imperfection: it was an old BS1363 plug with unsleeved pins.
On the other hand, this NEMA/BS1363 adaptor is hard to beat.
http://thereifixedit.com/2009/07/23/epic-kludge-photo-amateur-conversion/
