Tightening one to four set screws is quicker then making a comp fitting 'wrench tight'; therefore yes, less time consuming installation.
Advantages? both are approved connectior/fittings; some 'say' the compression provide a 'better mechanical fault path'. Compression(aka 'raintite') have a purpose.
