Anywhere with potentially high fault current requires bolt-on, because the electromagnetic forces in a full-blown short-circuit fault can be enough to tear cables right out of set screws, and breakers right off the panel.
If you're just fed from a small transformer (ala residential size) or otherwise have low availible fault current, then it's less of an issue.
