1 members (Scott35),
221
guests, and
10
robots. |
Key:
Admin,
Global Mod,
Mod
Posts: 8,443 Likes: 3
Save Energy LLC
Product Info
KVAR Power Factor 1200
You're using more electricity in your home today than ever before, it's still possible to lower your monthly electric bills with our Residential KVAR Power Factor 1200 Unit!
Why KVAR Power Factor 1200 Unit are so important? As the demand for the depletion of our natural resources and rising fuel cost for energy increases, so does the need for additional power plants. Our KVAR participants have already saved enough money and energy to help avoid building one additional power plant and saved millions of tons in the emissions from greenhouse gases.
How KVAR Power Factor 1200 Unit is installed? The KVAR Power Factor 1200 Unit is attached to the top 220/240 volt breaker/200amp service (we recommend to have your local electrician install for you). By installing the KVAR UNIT in this location, you are hitting both sides of the bus bar in your panel insuring whole house surge protection.
How do you achieve savings? When motors in your home start, they ask the utilities transformer for power (voltage and amperage) to run. This demand for power runs through the house wiring, thru the panel box, thru the meter and down the lines to the transformer. This demand for power heats up and strains the motors and wiring in the home, this heat (I2R losses) is watts. The KVAR Power Factor 1200 Unit once installed stores and releases to the homes motors what they need to function properly, thus reducing heat on the wires and the motors. Lowering this heat will reduce your electric bill, reduce the chance of fires and increase the life of the motors. Note: The KVAR Power Factor 1200 Unit is compatible with installation on the "older" designed fuse boxes. Ahh OK.
