Sounds like readings from a High Input Impedance DVM [Meter].
If things are functioning correctly, the Hi Z DVM readings would be somewhat normal.
If things do not function properly, it would either be a wiring / connection problem or problem[s] with devices - such as switches, lamp holders, motion detectors and such.
Scott s.e.t.
