Texas-Ranger:
Flying splices on the outside of the wall????
And this is the country that doesn't allow you to re-connect gas appliances after they're a certain age.
If I read this correctly, you mean absolutely no wall boxes are used for mounting outlets or switches or for holding splices on cable that goes inside the wall??? WOW!!
I can understand not using wall boxes if you use those round "tumbler" switches like the one you showed in a photo some time back.
[This message has been edited by SvenNYC (edited 10-23-2002).]
