Now there's the sort of Switch-board/Metering panel that I'm used to seeing.
Thanks for submitting the picture, Darren!.
Installing a switchboard in the Laundry is something that you don't see a lot of down in this part of the world these days.
Interesting to note that while the board has Porcelain Rewireable fuses on it, there is a plug-in type MCB sitting on the ledge in front of the board.
Bit of a rough job on installing that 2.5, it's not even covered with capping. [Linked Image]
