This is a picture of the switchboard & meter panel that was recently removed from my sisters house in Adelaide, South Australia. It was installed in the mid-1950s'. This board was mounted in the laundry at the rear of the property.
The meter on the left was used for measuring the power used for the house (rated 10-40 amps) & the meter on the right is for the hot water service (5-20 amps).
I have no idea where the cable on the left goes to, it's a length of 2.5 mm2 TPS cable for a power circuit of some description.
Under the left meter is the main switch, two fuses (the one on left is power-15 amps & the right one is lights -10 amps). The little box is for the neutral link.
The fuse in the centre along with the round switch underneath is for the hot water service.
On the end is a switch which controls the 10 amp power outlet below it.
The whole assembly has been removed & replaced with a 17 position DIN rail switchboard with RCD protection at the front of the property with the meters.
Darren Carroll
Alice Springs, NT, Australia
