Scott: BTW, I also have a smaller version of the Square D switch you show. It consists of the same two pole rotor switch, and a plug fuse for each pole. It's a flush mount enclosure, with a single door that exposes the entire insides (switch, fuses, and wiring).
Ironically, it even seems to be painted the same color as yours!
