John,
It was explained to me that this was to prevent a departing employee from removing the lock, and leaving an unsafe condition for the next shift.
Actually you are required by OSHA to do exactly that. You are required to remove your lock at the end of the shift. The rule does not permit you to leave your lock in place if you are not working on the equipment.
Don
