Interesting how they don't let you buy larger cables.
Does this lead to people doing DIY wiring with undersized cables?
E.g. if someone attempted to wire in a cooker or large water heater?
Paul: Speaking of cable sizes. I have noticed a lot of problems wiring certain new cookers here in Ireland that are obviously aimed at the European market. They have a 220/380 option..
The cooker has 5 terminals:
L1
L2
L3
L123 (connects across all phases)
The problem is that inserting the heavy cable used here for cookers is VERY difficult as the terminals seem to be designed for flex (The 3 phase set up would have thinner cables). Solid cable is normally used here for cooker connections not multi stranded stuff.
[This message has been edited by djk (edited 11-11-2003).]
