Belgian,
Follow up to an earlier message. Since I couldn't find any information on the switch or the package about maximum wire size I tested. I found that 6 mm2 can only be inserted with force. Hence, 4 mm2 appears to be the largest size that can be used.
[This message has been edited by C-H (edited 07-12-2003).]
