Trumpy;
The Designator FB5 could be anything! I am hoping it's an SMD fuse, so you can get this problem solved finally!
If you can figure out the maker of this M/Board, maybe they will have some "Usable" Tech Docs on line for that board, which could be used to figure out the component (along with other issues).
Man, that USB situation is really becoming a Giant PITA!!!
Just wish I had more help than questions!
Scott35
