Electure, my apologies for the incorrect protocol, partly my ignorance being a "newbie" here.
The only reason I posted this way is I remember moderators and admin got mad over users requesting to have pics posted. I just thought this way would be easier... setting up the post with the image codes and using my own server space, instead of hogging up ECNs space. But my apologies nonetheless.
As for the the water heaters, it's no joke. What's worse is their only complaint is the water heaters were shutting down when the lights were turned off, and all they wanted was the lighting to be rewired so a switch couldn't be used. Work was refused (too much money) to run a circuit for the water heaters and softner in EMT and three seperate single outlet NEMA-20 outlets... and bring an HVAC guy in to set the water heaters up properly... rewire, reinstall/check safeties, testing of gas pressure, draft, combustion testing, and so forth.
I'm done, letter is going out for my files.
Joe
