Shout Box
Tray cable?
by davistrembley. 02/22/19 07:53 AM
Light activation in closet by a broken connection?
by geoff in UK. 02/19/19 01:35 PM
AFDD's coming to the UK
by Texas_Ranger. 02/18/19 02:04 PM
Israel
by Texas_Ranger. 02/18/19 02:01 PM
What is this for?
Plug terminals
0 registered members (), 6 guests, and 23 spiders.
Disconnect Mounting #95875
10/16/05 10:36 AM
10/16/05 10:36 AM
wire dummy  Offline OP
Ohio
I need to mount a 100a switch over an existing single gang box in a wall.The conduit is 1.25 coming into the box.I have never mounted one over a box before.I thought I could just nipple it and be done. Any code issues or helpful hints would be appreciated.
2017 / 2014 NEC & Related Books and Study Guides
Re: Disconnect Mounting #95876
10/16/05 11:21 AM
10/16/05 11:21 AM
Larry Fine  Offline
Richmond, VA
I'd need a lot more info to respond to this, and a pic wouldn't hurt.
Is this an abandoned box, or are any wires in the box to enter the disconnect? I can't imagine 100-amps worth of conductors fitting a single-gang box.
If I had to venture a guess now, I'd say to mount an extension box over the existing box, mount the disconnect to one side, and nipple between them.
Larry Fine
Fine Electric Co.
fineelectricco.com
Re: Disconnect Mounting #95877
10/16/05 11:40 AM
10/16/05 11:40 AM
Ohio
Sorry,I see how I needed to be more clearer.There is an empty 1.25 coming into a 4 11/16 box with a single gang plaster ring on it.I need a 70 amp circuit there with a disconnect.There is sheetrock over the box.Thanks in advance.
Re: Disconnect Mounting #95878
10/16/05 12:38 PM
10/16/05 12:38 PM
dmattox  Offline
Anaheim, CA
Access to the box in the wall is an issue. I wouldnt consider needing to remove a disconnect to access a box as accessible. Larry's suggestion is how I do it. An extension box then go to the disconnect.
Re: Disconnect Mounting #95879
10/17/05 05:32 PM
10/17/05 05:32 PM
Ohio
I see your point.But,could I mount it over the plaster ring? Is this a code requirement?The wires would pass thru the box to the disconnect.I am more concerned with the code issue more than the convienance of mounting it.Thanks again.
Re: Disconnect Mounting #95880
10/17/05 08:25 PM
10/17/05 08:25 PM
earlydean  Offline
Griswold, CT, USA
No, I don't think that you could not mount the disconnect over the box and remain code compliant. You would need to maintain accessibility to the box beneath without removing the disconnect. I don't think there would be room enough in the disconnect to cut a 2-1/4 by 4 inch hole to get that access, nor would the listing allow you to modify the box that much. Is it possible to open the wall enough to remove the box, attach an offset bend, and enter the disconnect directly?
Earl
Re: Disconnect Mounting #95881
10/18/05 08:12 PM
10/18/05 08:12 PM
mxslick  Offline
Atomic City, ID USA
Maybe I've been missing something in this discussion, but IF there are no splices or connections of any kind in the box (i.e., the wire simply passes through the box on its way to a bushing on the rear of the disconnect), I don't see any problem at all.
Even if new conductors needed to be pulled through at a later time, I would think the box itself would allow enough bend radii to get 'em in.
Thoughts?
Stupid should be painful.
Re: Disconnect Mounting #95882
10/19/05 06:35 AM
10/19/05 06:35 AM
dmattox  Offline
Anaheim, CA
The code doesnt make an exception for a junction box that has splices or not. All junction boxes must be accessable.
Even so, What about your ground wire bonding both boxes, theres a splice for you.
Re: Disconnect Mounting #95883
10/19/05 10:35 AM
10/19/05 10:35 AM
gfretwell  Offline
Estero,Fl,usa
Is the disconnect part of "the building finish"?
Accessible (as applied to wiring methods). Capable of being removed or exposed without damaging the building structure or finish or not permanently closed in by the structure or finish of the building.
Re: Disconnect Mounting #95884
10/19/05 03:00 PM
10/19/05 03:00 PM
Ohio
Yeah,that is kinda my question/quandry.Is the disco considered the building?I also wouldn't splice the ground,just wrap the wire around the grd screw then go to disco(still a termination?).I am not looking to get around the code,just looking for some insight into the code issues.I have done similar installs on A/C units,but they are accessible.Thanks for the replies.
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
noderaser
noderaser
Portland, Oregon, United States
Show All Member Profiles
Admin 9
andey 3
253,299 Are you busy
189,915 Re: Forum
179,632 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.072s Queries: 15 (0.030s) Memory: 1.0242 MB (Peak: 1.2013 MB) Zlib enabled. Server Time: 2019-02-22 16:40:46 UTC
