1 members (Scott35), 110 guests, and 12 robots.
#94534 07/31/05 12:06 PM
what constitutes a canopie i have a 30 inch overhang on a house i am working on and want to use regular wp covers not the bubble in use cover. would most ahj accept this as damp location?
h20
#94535 07/31/05 12:31 PM
They don't where I'm at. But we get lots of sideways rain from strong tradewinds.
#94536 07/31/05 01:21 PM
That's an easy one- If it rains- does the rain hit the box? If it's in an enviorment where water is in use- Does it hit the box? Wet location. End of mystery.
George Little
#94537 07/31/05 01:26 PM
Article 406.8 covers the question. Per usual it's up to the AHJ to define. In this area an in-use cover is never installed on new construction exterior outlets, and is required on all pool-related outlets.
The enforcement of 406.8 here falls more into the area of 406.8(B)(2)....depends on the intended use.
Dave
#94538 07/31/05 01:55 PM
When you water the grass, shrubs or hose off the patio can it get wet?
#94539 07/31/05 06:02 PM
The "rule of thumb" I was taught was to considered the area under the eave, within a 45-degree area, to be "damp."
So, in your example, a 30" overhange woud create a "damp" zone for the top 30" of the wall.
Unfortunately, I have absolutely no "official" substantiation for this rule....yet!
#94540 08/01/05 11:22 PM
I agree with you reno
Larry LeVoir
Inspector
City of Irvine, CA
#94541 08/02/05 09:07 PM
F
Man can't remember exact code. But I think we follow the rule 3 feet is considered sufficient overhang to not require a bubble cover.
#94542 08/03/05 06:55 AM
What about during a hurricane.
Last year after hurricane jeanne I get a service call that gfci circuit tripping. The circuit feed outdoor and garage recp. Opening box after box and still no answer. I get to the last one that is chaulk, painted and untouched for some time. I razor knife the chaulking and paint to pry the cover off. About a quarter cup of water poured out of the box. Before I cut the cover off I did look for possible hole for water to get in but nothing but a little pin hole on side of cover in the chaulk. That meant the rain was diving sideways so hard it penetrated a hole the size of a ball point pen. The problem was cleared when the water was removed.
Under normal conditions the water would never have gotten in the box. But, now days in florida hurricanes are getting too normal. Even with a good size over hang some damp areas become wet.
In the 20 years in the field and 6 years as an EC, almost always the problem with water and outdoor outlets in not the opening to the outlets, but the seal behind at the wall or box. In-use covers just look good.
#94543 08/03/05 12:34 PM
"In-use covers just look good.
Tom"
I agree. I use the snap covers on the receptacles around my house, unless they will have unattended cords in them (only a few). I know it is technically a violation but driven rain is a problem on those bubble covers.
