#9415 04/29/02 06:41 PM
My company does a lot of wiring and general electrical maintenance and repair for small factories in our area and I thought that Thermal Video Imaging is something that I could offer my existing customers as a preventative maintenance measure and something that I could market to new customers.
I have been gathering information over the past year or so and might be ready to make a move.
I would probably purchase a still image camera with reporting software.
Does anyone out there use this now? What are your recomendations? What is your experience with this type of product?
#9416 04/29/02 08:34 PM
Thermal imaging is a great technology to find the "hot spots".The problem that I am familiar with is how hot is hot,thus it is important to obtain an accurate calibration.
Chris
#9417 04/30/02 01:22 AM
I've seen these cameras go for about $13K! And if ya got that kind of cash to throw around, throw some my way!
-Virgil
5 Star Inspections
Member IAEI
#9418 04/30/02 06:02 AM
The factory that I work at hires a company to come in and do IR scanning of all local disconnects and MCC buckets once a year. The technician spends an 8 hour day here.
They send us back a notebook documenting all of the problems. Each page of the notebook documents a single problem, and lists location, the temperature rise, probable cause, and recommended course for repair. Also, each page has a standard colored photo with arrows pointing to problem area, and a black and white infrared thermagram.
I personally have assisted the technician several times. Until a few years back, they used some real cumbersome video equipment that required liquid nitrogen cooling. The later equipment is much smaller, and does not require the liquid nitrogen. I do know that the equipment is very expensive.
When a problem is found, the technician videos the piece of equipment, and tunes the camera to determine the actual temperature rise. During the video, he speaks into a microphone and describes everything so that he can later compile the notebook of problems. He then snaps a standard 35mm photo. Some of the common problems that we find are worn out disconnect contacts, bad fuse clips, loose or corroded terminations, and blown fuses on power factor correction capacitors.
This service costs around $2000.00 a year, but we have found that it more than pays for itself in preventing down time.
