ShoutChat Box
HVDC Greece to Crete
by gfretwell - 08/06/20 02:28 AM
310.15 (B) 7 Feeders
by HotLine1 - 07/31/20 02:29 PM
What would be the ideal solution?
by Fleppin - 07/21/20 12:42 AM
NESC question
by gfretwell - 07/16/20 04:17 PM
Code Violation or just not good Practice?
by HotLine1 - 07/16/20 03:03 PM
Facebook follies, bad wiring
FPE in Germany pt.2
0 registered members (), 15 guests, and 14 spiders.
50 amp hot tub #94070 07/05/05 11:33 PM
watersparkfalls Offline OP
can you use nm 8-3 to feed a 50 amp hot tub?
2017 / 2014 NEC & Related Books and Study Guides
Re: 50 amp hot tub #94071 07/06/05 12:21 AM
gfretwell Offline
I think not. NM is not one of the approved wiring methods in 680 part II. I also could have problems with the ampacity, based on the nameplate rating of the spa and mfg instructions. 8ga is only good for 40a in the 60c column.
Re: 50 amp hot tub #94072 07/06/05 07:16 AM
George Little Offline
Greg- The question is not stating whether it is an indoor or outdoor spa. 680.42 and 680.43 come into play here.
George Little
Re: 50 amp hot tub #94073 07/06/05 09:30 AM
it is an outdoor hot tub
Re: 50 amp hot tub #94074 07/06/05 04:44 PM
Electricmanscott Offline
Are you asking if you can run NM outside to a hot tub?
Re: 50 amp hot tub #94075 07/06/05 05:59 PM
shortcircuit Offline
Romex (type NM) is allowed in the interior of a one family dwelling or the interior of a structure associated with a one family dwelling...
But read the instructions with the tub and labels at the control box behind the skirt of the tub. Some require a full size EGC to be run with the circuit conductors...
shortcircuit
Re: 50 amp hot tub #94076 07/06/05 06:25 PM
boggerbutt2454 Offline
Shorties right read your Manufacture's manual most spa manufacture's will put min. wire size and I've found more times tahn not it is a #6 copper, but check your manual. If customer doesn' know call dealer they bought it from.
Re: 50 amp hot tub #94077 07/06/05 06:38 PM
iwire Offline
If NM is in fact appropriate 8 AWG NM can not be used above 40 amps.
Re: 50 amp hot tub #94078 07/07/05 02:22 AM
no i am not asking if i can run the nm outside. just wondering if i can calculate hot tub as a motor to use smaller wire.
any thoughts against using 6-3 aluminum?
Re: 50 amp hot tub #94079 07/07/05 12:52 PM
gfretwell Offline
A spa is a combination load with a significant part that is a "toaster wire" heater. The answer is in the manufacturer's instructions unless you want to start reading nameplate ratings and calculating.
You are still stuck in the 60c column with Romex.
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Show All Member Profiles
BigB 3
268,556 Are you busy
202,949 Re: Forum
191,329 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
