0 members (), 240 guests, and 32 robots.
#93093 05/02/05 09:18 AM
Talked to a freind the other day he installed some lighting and removed the white stickers on the base 60 watt max well some how they put in a larger bulbs and fried the wiring homeowner says his fault because he removed the labels. Hell doesn`t everyone.I finished a house yesterday and the outside fixtures had big white sticker on the glass 60 max of coarse I installed a 60 and removed the ugly sticker.
Workgear for Electricians
#93094 05/02/05 09:40 AM
Reel-Break, manufacturers safety warnings and instructions must remain on the equipment. Your friend (and yourself) may have just learned an expensive lesson.
If the homeowner removes these stickers so be it.
Roger
#93095 05/02/05 07:59 PM
e57 Offline
I get asked to remove them from time to time and wont do it. Because they also want you to remove the sticky goo too. Damaged a frosted glass fixture like that once, won't do it again.
I have also been known to put new ones on when the old one aren't legible, or missing. Any excuse to pull out a label maker really. But I'll go out on service calls for cans and find over-lamped trims where the owner couldn't figure out which trim they had and lamp to use, and out comes the label maker.
